enzie wrote:There's propably speed limit remover/converter installed behind the dash.I have one of these also and it can be selected with a dip switch it it does that on startup to confirm operation.
Cant remember the make of it but it bolts directly behind the speedometer bolts.
.the only thing I can promise for sure is slow progress.
just have this niggling thought that if I rip out the wiring, then the car will never get out of the garage again.![]()
Shmed wrote:is it possible that the speedo converter has gone wrong as I no longer get the test sequence?
Moo wrote:I have the instructions.Do you still need them?
