Toyo t1R's wobbly??
Toyo t1R's wobbly??
has anyone here put these on the back of their tubby?got em yesterday for mine and ive never felt so nervous taking bends in my life.the car pulls from left to right when accelerating in a straight line.when you go around a bend and straighten up the wheel the car wobbles.i dont feel safe at all.and before that i had 2 different cheap tyres on there which were like slicks they were so bad an the car still handles great.cant understand this as ive had t1r's on a few cars an thought they wer a solid enough tyre.but they feel like remoulds on my 2.anyone else have any experience with these or is there somethin that was done wrong that might be causin this?cheers.
Re: Toyo t1R's wobbly??
not had them on the rear, but they will be better than the cheapo tyres.
maybe the increased grip is highlighting some poor alignment.
take it for a fresh alignment then see how it feels.
You'll need to leave it about 300 miles to get them scrubbed in.
they either move about on the new high tread blocks, take a while for temperature cycles to firm up the sidewall or it takes ages to get rid of the slippy lubricant
which helps the tyre out of the mould.
Either way I've had about 3/4 sets now and it's always the same with the rears.
just wait awhile and put some miles on them and all will come good.
R.
R.
cheers for the quick replys.ah thats good so.i thought that but i done about 100 miles an they were still the same so i thought they were just a bad tyre.thats all i needed to know my mind can relax now
cheers
I set my pressures to:
32 front
36 rear
But always have 4 psi difference I'd say.
Get a 4 wheel alignment done with new tyres
- ALWAYS
Allow a couple of hundred miles until they are scrubbed
Lastly, you bought a full set so they are all the same right
32 front
36 rear
RobPhoboS wrote:I set my pressures to:
32 front
36 rear
Get a 4 wheel alignment done with new tyres- ALWAYS
Allow a couple of hundred miles until they are scrubbed![]()
Lastly, you bought a full set so they are all the same right?
oh rite.ya i know i shouldve got it done.but ah no i only got em for the back as my back ones were completly worn.ive advan ad07's on the front an there perfect so wasnt going changing em.
Yep, I understand it's not always easy to do all of them but along with the brakes they are the most critical aspect on a car/bike.
It's really worth changing all of them so they match, then at least when one axle set needs replacing, you are still buying the same spec tyres.
You could always just sell the ad07's for a few quid, always someone who'll want them I'm sure
But definitely get the 4 wheel alignment sorted
RobPhoboS wrote:It's really worth changing all of them so they match, then at least when one axle set needs replacing, you are still buying the same spec tyres.
What? There is no need to replace front and rear at the same time.
I asked God for a bike, but I know God doesn't work that way.So I stole a bike and asked for forgiveness.
No need for alignment checks with new tyres so long as the new wheel/tyre is properly balanced.
alignment and geo is a separate issue which should be checked at least annually anyway.
For just new tyres all you need is them balancing.
As for different rubber f/r.
ideally you'd have the same compound all round but don't change for the sake of it if it feels OK.
Just wait till the fronts are ready to be replaced and then stick the toyos on.
R.
PS If you still find it wallowy a bit more pressure in the rears
(I go to about 38/40psi.
max pressure minus 10%) should help just till the tyres are properly scrubbed.
R.
You guys can do what you want in your own cars, no worries, I'm just saying what I do and it's up to the OP what they do.
toyo's have that feeling, plenty of threads about tyres and toyo's in particular
I just had 4 of these fitted yesterday the difference its made to the handling is awesome.
I agree about the wobbly feeling.
Always had proxies on my mr2's.
To solve this l run
34psi front
38psi rear
Car feels much better.
34psi front
38psi rear
The T1R is my number-1 hated tyre on an MR2.
they feel terrible on a track day, and frankly are nothing special on the road.
If you are looking for a cheap trackday tyre, that in my opinion is actually a really really good all round tyre
- Try the Marangoni Zeta Linea.
I think you can only get them in 16" and upwards.
I paid
£206.50 for a complete car set back in 2008, they impressed me both on road and on track
- I've been through most MR2 fitment tyres in the last 10 years
Paul
I paid
Paul
sticks wrote:has anyone here put these on the back of their tubby?got em yesterday for mine and ive never felt so nervous taking bends in my life.the car pulls from left to right when accelerating in a straight line.when you go around a bend and straighten up the wheel the car wobbles.i dont feel safe at all.and before that i had 2 different cheap tyres on there which were like slicks they were so bad an the car still handles great.cant understand this as ive had t1r's on a few cars an thought they wer a solid enough tyre.but they feel like remoulds on my 2.anyone else have any experience with these or is there somethin that was done wrong that might be causin this?cheers.
I had this with T1Rs on the rear of my tubby.
It'll take a month for them to settle and behave like proper tyres.
I know I won't be getting them again.
Think I may try the Fedral RSRs next or something similar.
P.S.
