[Mk2] [Generic] MR2 With Supra Wheels
jberry3
Post by jberry3 »
Just see this pic while searching this site and think the supra wheels look mint on mk2!
Does anyone else have pics of them on mk2's?
Also how practical are they? Rubbing, fitting etc?
fearless
Re: [Mk2] [Generic] MR2 With Supra Wheels
Post by fearless »
there was a post on fitting these some time ago, i believe spacers were needed and tyres needed to be changed as they caught from memory, im sure someone will post up the post for you i cant use the search function im afraid. :thumleft: :thumleft: :thumleft:
sw20
My Supra Wheels
Post by sw20 »
Here's a couple of pictures test fitting my 16" Supra wheels on the rear with 15mm spacers and a 245/45/16 Tyre on which cleared with loads of room.
Going to run a 215/45 tyre on the front also with 15mm spacer kit, Hope to have these fitted after my engine work. :thumleft:
stealth
Post by stealth »
Just seen this,
For anyone else who finds this:
The car in the first pic is mine, those wheels are the 17" Supra wheels, they were never fitted to the car, we took them off a mates supra and put them on mine just to see how they would look. They were very tight up against the suspension and so the car was undrivable like it, I would say big spacers would be needed and arches rolled as a minimum at a guess.
They look sweet on an MR2! 8)
Nic
Post by Nic »
Stock Supra wheel sizes
16x8 +50
16x9 +50
17x8 +50
17x9.5 +50
Using the wheel calculator below, it looks like you'd need at least a 10mm spacer on the front so the wheels would clear the suspension
http://mr2.gordaen.com/wt_calc.php
MR2 (mkii) Flushness:
Your proposed front wheel will be 14.65 mm tucked in from flush (flush offset: 35.35).
Your proposed front is 9.35 mm into the suspension!
Your proposed rear wheel will be 8.3 mm tucked in from flush (flush offset: 41.7).
stealth
Post by stealth »
I tried a 10mm when I had them, not enough to clear the coilovers, and would hit the arch liner.
Whitey
Post by Whitey »
I have fitted the 17's on the rear but need lower profile tyres and spacers fitting to the front to clear the suspension.
I have 10mm hubcentric spacers I'll try but got a feeling i may need more, also going with slightly stretched tyres front and back to sit snug in the arches.
Also fitted a crash bolt to the rear strut on one side to give me a mm of movement, it's that tight!
PeterRST
Post by PeterRST »
Here's mine on Mk3 Supra wheels
