Tom-os wrote:I've got extra boost as i've got a straight through exhaust, gutted cat, airfilter and hks bov.
This alone has raised my boost to around 12psi.
So just wanted to double check that i should still disable the TVSV?
Tom-os
Right, with you now.
You should have mentioned it in the first place but hey ho
If the turbo is producing
"extra" boots with the stock boost management in place, then you certainly do NOTsteed to remove the VSV from the equation.
The most likely source of your issue is the free flowing exhaust/downpipe that you have.
It could be one other issue that I can think of, but I'll come back to that later.
The CTxx series turbo have a very poor flowing wastegate by design.
What this means in laymans terms is that the wastegate cannot really flow enough exhaust gas away from the exhaust turbine to control its speed and hence the boost that the turbo will produce
(as the inlet turbine is attached to it by the shaft).
In stock set up, this seems to be hidden by the fact that the CAT and exhaust are a little restrictive and they slow the exhaust gases down.
This has the side effect of slowing the exhaust turbine down and
"holding" it at stock boost.
When you remove these restrictions
(by way of fitting a downpipe and free flowing exhaust) the true problem comes to light in that the wastegate alone can no longer divert sufficient gas to control the turbine speed.
The VSV works by bleeding a small amout of boost away from the actuator under certain conditions
(when the engine is warm, in certain gears, as long as there are no serious malfunctions detected by the ECU).
This has the effect of raising the boost produced.
You could, if you wanted to, dissable the VSV but all that would do is prevent the lower amount of boost being acheived under the opposite of those conditions, it wouldn't prevent the extra boost that you're seeing.
Lastly, the one other condition that could raise the boost being produced is if the timing is so far out that part of the combustion is taking place outside of the cylinder
(hot gases flow fast and make the exhaust turbine spin faster).
So it might be worth you checking your timing is correct as a start off point.
Sorry for the rather long post, I'm bored lol.
Edit: Made a boo boo on the description of the VSV.
