[Mk2] [Turbo] No indicators or hazards
cooper
Post by cooper »
I have just purchased a rev1 turbo gt t-top and none of the indicators work or the hazard lights, is it common for the relay to head south?? if so where abouts are they located?
cheers in advance
Shaun :mrgreen:
Lewis Jay
Re: [Mk2] [Turbo] No indicators or hazards
Post by Lewis Jay »
Does your horn work?
Have you checked the hazard fuse its in the front?
cooper
Post by cooper »
yes horn does work, where abouts in the front is the hazard fuse?
sparki
Post by sparki »
iirc if the hazard switch isnt plugged back in none of the indiacators will work.
Mr2_NA
Post by Mr2_NA »
sparki wrote:iirc if the hazard switch isnt plugged back in none of the indiacators will work.
+1 - Correct.
Check it's plugged into the back of the haz switch if the fuse is ok.
Return to “Electrical”
