Plastic end clip of the engine cover stay....
DTMr2
Post by DTMr2 »
Hello guys,
I've got a question about the plastic end clip of the engine cover stay....
Before I go to the Toyota main dealer to ask and for them to look down at me,I'd like to know wether I'll be able to buy just the plastic bit from them.I'd rather not have to buy the whole stay,rod and all.
I'm only after the plastic clip that actually clips into the inside lid of the engine cover.Mine is damaged and lost a tab bit.
I went to a local scrapyard and found one but that was even more damaged than my own one.
Many thanks guys.
reddev1ll09
Re: Plastic end clip of the engine cover stay....
Post by reddev1ll09 »
Hi,
I can't make out from your description what part it is your looking for :-k
Is it part of the engine cover stay itself ?
or is it the small clip attached to the middle of engine cover, that holds the stay in place when not in use ? (lid closed)
I have just bought a gas strut & my stay is no longer needed so if it's a part of the stay you need, you can have mine
(no charge)
If it's the other part 'clip' that holds in place, I can't help as my clip has snapped. That's why i bought a gas strut.
Slarty
Post by Slarty »
If you're refering to the plastic clip that holds the engine cover strut to the engine cover when the strut is not in use, the part number you need is 53455-17040. They're about £1.50 from Toyota so not too bad ;)
Marf
Post by Marf »
^^ Yep as above, they are available from Toyota cheaply, I had to replace mine the first month I had my 2.
DTMr2
Post by DTMr2 »
Slarty wrote:If you're refering to the plastic clip that holds the engine cover strut to the engine cover when the strut is not in use, the part number you need is 53455-17040. They're about £1.50 from Toyota so not too bad ;)
Thank you very much Slarty :clap:
Wait a moment,is that the clip in the middle of the engine cover?
Sorry,if it is.I'm looking for the clip on the other end.It's on the right/offside.
Many thanks,guys :thumleft:
DTMr2
Post by DTMr2 »
reddev1ll09 wrote:Hi,
(no charge)
Hey Reddev,where did you buy the gas strut? Sbits?
Seems a very good idea :-k
It's the clip that's supposed to stay clipped in the hole,on the right/offside.
reddev1ll09
(no charge)
I bought it from a fellow member m8
I have a full stay/rod/pole :lol: whatever it's called if you want it (with the clips on it, each end)
Slarty
Post by Slarty »
On this diagram, do you mean the part numbered 64407A?
http://www.ayrpark.plus.com/epc/toyota/ ... _1993.html
If so, the full part number is 64407-17030.
DTMr2
Post by DTMr2 »
Thank you very much,Slarty :thumleft:
DTMr2
Post by DTMr2 »
(no charge)
Thanks reddev,but have a spare rod already.
Only looking for the plastic clip bit.
reddev1ll09
I have the full stay sitting doing nothing, so if you want just the small part/clip on the end of it you can have it (no charge)
as i say the stay is not being used anymore.
DTMr2
Post by DTMr2 »
You have PM :wink:
