this was my original list i have made aload of modifications to this over time
WRC Group A inconel manifold
(1 of only 8 on the globe)
Garret GT3076R
.082 AR, turbo, with ceramic coated exhaust housing
Custom made 4' down pipe
Tail 42mm external wastegate
Custom 95mm throttle body
Custom inlet manifold
Goodrich braided oil lines and fittings
Custom,vent to atmosphere screamer pipe
CP Forged pistons, 86.5mm, 8:5:1 C/R
Carrillo H beam conrods, rated to 1100bhp
Carrillo conrod bolts
HKS 264 cams
HKS cam pulleys
HKS fine tune cam belt
HKS BOV
Cometic head gasket
Toyota full gasket set
Cometic bottom end gasket set
ARP racing head studs
ARP racing main studs
ARP flywheel bolts
ACL full race bearing kit
ACL thrust washer kit
Samco full ancillary hose kit
Samco full coolant hose hit
Samco 4' turbo induction hose
HKS 4' induction mushroom
Custom 95mm pipe kit, samco hose kit with clamps
Toyota, water pump, oil pump, tensioners and idler
Toyota TRD low temp thermostat
Toyota TRD oil filter
TRD magnetic sump plug
Century motorsports poly engine mounts
polished engine bay, chromed heat shields, custom crackle paint rocker cover
Full stainless steel engine bolt set
Toyota rev3 refurbished gearbox
Kaaz 2 way slip differential
OS Giken billet multi plate STR clutch kit
OS Giken flywheel
Spitfire ignition leads in blue
Walbro 305ltr fuel pump
AEM fuel pressure regulator
Sard 1000cc injectors
Sard fuel rail
GM 4bar map sensor
Boot mounted hux intercooler
2x 11' boot mount spal fans
Apexi high flow single exit exhaust system
Apexi Power FC ECU
Apexi ECU hand commander
HKS EVC 6 boost controller
Devils own water methanol injection system
Custom made meth tank
Link knock sensor and display
PLX systems wideband 02 sensor and module
PLX systems multi read out 60mm digital gauge
Rogue motorsport twin spal engine lid fan kit
Apexi boost guage
Stepper gauges 52mm, oil pressure, oil temp
HKS fuel pressure gauge
Bride tachometer
HKS oil catch can
Titanium red wheel nuts
Full cusco roll cage
Driftworks 6 point orange harnesses
Corbeau Kevlar bucket seats
Braided Hell clutch hose
HKS fan controller
Pirreli, p zero rosso tyres all round
EBC grooved discs
EBC redstuff brake pads
Greddy titanium oil filler cap
Toyota wind deflectors
Snap off steering wheel hub
GTS Chris uprated gear shift bearing kit
