[Mk2] [Turbo] Where to get ARP moly lube? Or, what to use instead?
jwarren2k2
Post by jwarren2k2 »
Hi all,
I'm fitting flywheel tomorrow and have bought some ARP flywheel bolts. They didn't come with the ARP moly lube/grease.
Is there anywhere local that would do the lube/grease please? If not, what could I use instead?
It says 30 weight oil and to increase the torque from 85 ft.lbs to 105ft.lbs, but I don't have any 30 weight oil.
Any help would be great,
Thanks! :)
Slarty
Re: [Mk2] [Turbo] Where to get ARP moly lube? Or, what to use instead?
Post by Slarty »
You don't have to use the ARP lube, or in fact any lube. Just do the bolts up to the dry spec torque which in this case is 85lbs :thumleft:
