Apologise if this is already covered. I have used the search, but nothing conclusive. Can some one please confirm the correct spark plug gap for my mods?
Rev 3:
3 " Turbo back system.
Apexi Induction.
HKS Intercooler
NGK Leads
Running 1.0 bar on stock CT20.
Thanks.
Only mention of a spark gap is 0.6 mm. The only mentions of gaps I've seen recommended have been 0.8 or 0.7. can any one confirm which one of the 3 gaps to use?
I know this is an old thread but I'm trying to find out if there are any charts, or if anyone can tell me what the gap should be a certain boost levels.
I'm using HGK BKR7E plugs and running between 1 - 1.2 bar with a 205 charge cooler.
Any help greatly received.
There is a very simple answer which covers all permutations of plugs, ignition systems, component condition and boost levels:
You run the biggest gap you can without the spark being blown out.
Simples
