Fuel filter location?
Hi, Does anybody know where the fuel filter is on a rev3 turbo? Also is it easy to change? Thanks Gavin.
Re: Fuel filter location?
hi mate, it is under the air filter area on the rear firewall, best done from underneath
coulple of banjo bolts either side of the filter and two bolts i think holding it on
Thanks alot, might give it a go tommorow then if the weather holds out
Guide here, with pics...
http://www.mr2oc.co.uk/know-your-2/mk2/ ... ilter.html
