Sorry fella I don't understand why he couldn't balance the rears for you? Is he saying they wouldn't go on the machine for some reason? Obviously cost is always a factor but if you can a full geo set up
(balancing wheels is a different issue, you also need to consider camber, castor and toe angles to get the best from your 2) every 2/3 yrs will keep everything in fine fettle.
These cars are very sensitive to their geometry.
As for the non balancing issue if we knew why he couldn't it would help.
If it feels fine chances are it is though you'll obviously feel any rear vibration less than the front.
Pop it to another place to get the rears checked? Where are you?
R.
