[Mk2] [Turbo] therostat stuck open??
pistol pete
Post by pistol pete »
well when i bought the turbo
dash temp not working...
but i have recently noticed that it moves to just above the c on cold when standing still and drops down a bit when moving
with the cold weather could it be the thermostat is stuck open??
i am later this week chanign the sender and the thermostat and coolant as its quite brown so in need of a change
wondering if there is a small block somewhere as the fans blow warmish.. not hot..
so 2nd Q is what should i use to flush the coolant system out other than just leaving water running though for a while or is that the best option....
cheers
C50
Re: [Mk2] [Turbo] therostat stuck open??
Post by C50 »
I doubt it's the cold weather, it should warm up eventually if standing still :-k
sounds expensive to flush out the system other than using water. I shall be flushing mine out with water and using the Halfords Advanced "mix it yourself" coolant :)
raptor95GTS
Post by raptor95GTS »
sounds like the thermostat is stuck open. You can flush with plain water, certainly I did that with the mk1 the mk2 was looked after better by the previous owner and then by me.
toxo
Post by toxo »
Either that or it's had overheating problems in the past and someone's drilled the thermostat.
pistol pete
toxo wrote:Either that or it's had overheating problems in the past and someone's drilled the thermostat.
illl find out 2morrow.... got new thermostat... depends on weather..
but done some miles in it and no signs of overheating...
C50
Post by C50 »
my old one, the rod bit inside came apart and was wedged open
tommy-c
Post by tommy-c »
I had the same symptons as you when i bought my turbo, replaced the thermostat and all was good, the thermostat i took out was clearly stuck open.
*Appartently* quite common on 3s-gte's
I used toyota's 4life coolant (£££'s)
