[All] [NA] Engine overheating NO Heat through car
mr2greenmachine
Post by mr2greenmachine »
I have only went and bought a mr2 (1992) had it a week problems all round but this one i cant fix not sure off where to start. The engine over heats after 5 mins. but i get no heat coming through the air vents. I need help where to start ](*,) . New to all this stuff cheers :thumleft:
As u can see i dont know much about mr2 yet but u can all let me know if it mk 1 2 3 cheers ?!?!?!??
DAN_REV1_TURBO
Re: [All] [NA] Engine overheating NO Heat through car
Post by DAN_REV1_TURBO »
It would be a mk2 mate being `92 (mk1 is the squarer original shape MR2). Or if you mean which revision, yours is prob a rev2,if u get your chassis number u can find out for definite. Theres a post on here somewhere that states where the revs start and finish by chassis number. I dont know a lot but last time I had a N/A with those symptoms, it was the headgasket gone. Or I dont know if a stuck thermostat could cause it?
DAN_REV1_TURBO
Revision 1 - December 1989 to December 1991
Chassis JT163SW2000000001 to JT163SW2000059265
Revision 2 - December 1991 to November 1993
Chassis JT163SW2000059266 to JT163SW2000087385
Revision 3 - November 1993 to June 1996
Chassis JT163SW2000087386 to JT163SW2000106662
Revision 4 - June 1996 to December 1997
Chassis JT163SW2000106663 to JT163SW2000110780 (Approx)
Revision 5 - December 1997 to August 1999
Chassis JT163SW2000110780 (Approx) to End of Production
mr2greenmachine
Very helpful cheers . Know where I can find a work shop manual so I can diagnose the problem. And solve lol hoping
smig
Post by smig »
Have you checked your coolant level?
zombie_dave
Post by zombie_dave »
i would replace the cooland and bleed the system before taking it to have the HG done
HighwayStar
Post by HighwayStar »
Where are you fella? It might be easiest (and perhaps cheapest in the long run) to whip it to an affiliate for a diagnostic of the issue. Meanwhile have you checked the oil filler cap for signs of white gooey build ups?
R.
Jaspa
Post by Jaspa »
Where abouts is the water spewing out of? if it is the expansion bottle, Replace the pressure cap (About £5 from Halfords etc)
I asked God for a bike, but I know God doesn't work that way. So I stole a bike and asked for forgiveness.
