[Mk2] [NA] Sump fitting
steffs
Post by steffs »
Will a turbo sump fit my non turbo 1991 mr2??
Matt@Rogue
Re: [Mk2] [NA] Sump fitting
Post by Matt@Rogue »
There physically the same size and shape, so yes... the turbo one won't have a level sensor hole but odds are neither will your n/a.
Si_Crewe
Post by Si_Crewe »
Will a tubby sump fit above the exhaust on the n/a?
Wingers
Post by Wingers »
There's also a turbo oil drain into the sump on a tubby (at least there is on my rev1). You might need to block that somehow unless it's used for something else on an N/A.
Wingers
