engine
wossner86.5 pistons
3s main bearings
acl tri metal big end bearings
3s thrust bearings
arp con-rod bolt set
cometic headgasket
trd thermostat
new oil pump
new water pump
toyota oil cooler
gates rev2 cambelt and idlers
lightweight crankshaft
arp head studs
gd 7 irridum plugs
eagle forged conrods
special camshafts
adjustable pulleys
hard anodised retainers
uprated valve springs
cylinder head ported and polished
radtec chargecooler
twin fan kit
gt2876r turbo
air filter
transmission
new gearbox longer 5th gear with trd diff
rps 525ft/lb 6 puc clutch
light weight flywheel
fueling
blitz 850cc injectors
walbro 255/hr fuel pump
engine managment
link g3 ecu
blitz boost contoller
got launch control set up on it
wheels&suspension
lenso white 17" alloys
normal shocks and springs
interior
greedy turbo timer
boost,oil temp&oil pressure gauges
painted white dash
black and white leather seats
10"sub
1 amp
2 6"9" speakers
alpine head unit
smaller steering wheel
exterior
bigger front lip
lexus rear lights
twin air scoops
dark crystal front lights
exhaust
blitz nur spec
performace is 389 and 352ftlb torque 12.3@118 down 1/4 mile the car is allways garaged and has 4 months tax and 7 months mot and has passed the last 3 mots with no problems am looking for
![Image](http://i184.photobucket.com/albums/x56/craigmr2/craigscar008.jpg)
![Image](http://i184.photobucket.com/albums/x56/craigmr2/magpics015-1.jpg)
![Image](http://i184.photobucket.com/albums/x56/craigmr2/craigscar002.jpg)
![Image](http://i184.photobucket.com/albums/x56/craigmr2/craigscar006.jpg)
