Fantastic basically
- I'd recommended them unreservedly, and I'm a picky bu88er normally.
By far the best tyre I'd driven, wet or dry.
The only fault I could put on them
( and its not a major one
) is as they wear down you get more tyre
/ road noise, and with the tread pattern on it can sound like a wheel bearing on its way out.
Yes a set will cost
£440ish against a set of T1Rs coming in at around 220 but the additional grip and progression is worth it.
Tyre wear rate is fine too on the Neovas
- they're not some super soft special that wears out in a few thousand miles.
I'm doing
~ 10-15k miles on a set of rears, and 20-25k for the fronts.
