[Mk2] [NA] 95 rev3 power steering rack play
stev
Post by stev »
have found slight play on the inner side of streering arm can these be replaced ?? is there repair kits??? :roll:
just cant be bother to take out the hole rack inthis weather ???
Quigonjay
Re: [Mk2] [NA] 95 rev3 power steering rack play
Post by Quigonjay »
from your description it sounds like you are reffering to the inner track rod, yes it can be replaced
http://www.camskill.co.uk/products.php? ... s610p11811
stev
rev 3 power steering arm
Post by stev »
Quigonjay wrote:from your description it sounds like you are reffering to the inner track rod, yes it can be replaced
nice one as soon as the snow goes will be doing this thank again
