If you cant see coolant in the filler neck fill it up.
Check again a few days later and fill again if necessary, if it still drops you have a leak.
Ideally the level should be right up there.
Mine is always right up to the top of the filler neck.
Check the jubilee clips are tight on all the hoses as this was where mine was leaking from.
