[Mk2] [Turbo] Wiring Looms
kev_mr2
Post by kev_mr2 »
Ok guys litle bit info needed.
My donor shell for my build is a K plate Rev 2 Tubby, however the chassis loom leading to the engine bay and the dash loom have both been cut to bits.
I have replacement looms for both but they are taken from my Rev 1 that i acquired the engine out of.
Question is, are they the same looms so i can just plug and play? also would it be easy enough to run a wire for the electronic speedo cos i have the electronic clocks?
Thanks in advance
Return to “Electrical”
