still have problem got the car open , got door lock out had a key made and it fits ok , now i can:t get it to operate the ignition nothing lighting up on the instrument panel anyone got any idea , it has got me baffled the car was fine before i lost the keys ///////???????? lencee
First port of call is checking that the battery still has some life in it, should be able to check by trying some of the lights etc which should work independently of the ignition.
[battery is fine getting power to lights horn radio wipers but nothing when
you turn key in ign. no warning lights on he instrument panel just the volt meter that does register
Is the key turning the full way? How many 'stages' does it turn.
And was it the same key on the door as the ignition?
And does the car have an imobiliser?
