It's not as if Luke and co need another glowing report in here, but here goes anyway!
I ripped my front gearbox mount out about 4 months ago, the thread inside the gearbox crumbled and the bolts had nothing to attach to.
Luke took my gearbox off, drilled out the holes and put some strong threaded inserts in there, and put it all back together again.
While he was in there he identified worn driveshaft seals, a bent driveshaft guard and a couple of missing bits and pieces, as well as an oval shaped shifter bush.
All these were replaced
/ fixed when I picked the car up.
He also found the
file handle
I'd used to bung the recirc pipe on my induction kit and replaced it with a proper blank, and identified a very infuriating intermittent oil leak.
I also had TRD engine mounts and a Fidanza flywheel fitted, and had my old intercooler removed.
I was kept up to date throughout and my car is now awesome to drive again
And all this over the course of a weekend
(bar waiting for the driveshaft seals from Toyota) for a few hundred notes.
Top marks!
My car needs the oil
& water pumps replacing shortly and it won't be going anywhere else.
