What I was doing in 1982
bobhatton
Post by bobhatton »
Quigonjay
Re: What I was doing in 1982
Post by Quigonjay »
dude, you need a haircut :D
interesting read. so what else have you done? :mrgreen:
bobhatton
Post by bobhatton »
Did some work on the F1 turbo set ups to get boost in early, had one or 3 British touring car teams running nitrous as well as a British rally cross champion. Turbocharged two outboard engines. lots of things like that.
Bob
Steve Horrocks
Post by Steve Horrocks »
I was 4 months old at that issue!
And cant believe CCC was 70p never mind going all that time back!
Can't read it all yet as browsing on phone but will look tomoz.
Quigonjay
Post by Quigonjay »
would be interesting to know if, 27 years on, you are still championing the water injection?
you mentioned about people just needed educating about it, bet nowt much has changed there :lol:
i'm guessing you have driven quite a few different cars, how does the mr2 turbo compare in your opinion?
what have been the major developments/changes on the tunning scene since you started?
Ryan S
Post by Ryan S »
i wasn't even born until 31st may 1983!!!!!
Stu.
Post by Stu. »
nice read,i like this bit:
i want more power we'll just drill the jets out
superb !
bobhatton
Post by bobhatton »
Quigonjay wrote:would be interesting to know if, 27 years on, you are still championing the water injection?
what have been the major developments/changes on the tuning scene since you started?
Yes I think any turbo should be using water, it works so well when the installation is right. And when I say right I mean having the injectors in the manifold runners down by the head, not just one up by the TB. The benefits of water only take place in the cylinders not in the manifolding.
Back in 2000 I had the money to get almost any car I wanted, the one I went for was the MR2. I think it does everything I want in a car very well. I like cars I can change, I have never had a standard car.
The most fun I had was in a big block AC Cobra on the way down to Kent one evening going to pick up a new carb for it. No cars on the road so put my foot down, I took it back off when everything was a blear, about 190 mph.
The other was when I fitted nitrous on a Lancia Stratos. From a standing start it did not stop spinning the wheels till I was in 5th gear.
Bob
Dale_V
Post by Dale_V »
very cool bob, VERY cool indeed 8)
(ps, 1982... I was still being conceived :-k :eye: )
bobhatton
Post by bobhatton »
Stu. wrote:nice read,i like this bit:
superb !
That is just what it is like.
I went up to an engine dyno one day to set up a system on a hill climb car.
The engine was a 1600 race engine giving 250hp and the driver wanted an extra 100hp. So we ran the engine up and I just drilled out the jets till we got what he wanted................easy
Bob
bobhatton
Post by bobhatton »
Dale_V wrote:very cool bob, VERY cool indeed 8)
What all year long? \:D/
Quality post Bob :thumleft:
1982, August....I was 4 months old :mrgreen:
bobhatton
Post by bobhatton »
Thank you all but please stop telling me how young you all are :(
Bob
marc GT Turbo
Post by marc GT Turbo »
i was 13 in 1982 bob :thumleft:
1993 GT TURBO
bobhatton
Post by bobhatton »
That is better, but I was 34 so you are all still young lads :thumleft:
Bob
Quigonjay
Post by Quigonjay »
bobhatton wrote:Yes I think any turbo should be using water, it works so well when the installation is right. And when I say right I mean having the injectors in the manifold runners down by the head, not just one up by the TB. The benefits of water only take place in the cylinders not in the manifolding.
at the throttle body is the only way i have seen it done on an mr2, is this not really worth doing then?
by "down by the head" do you mean drilling/tapping the inlet manifold? one injector per cylinder?
cheers
Jay
bobhatton
Post by bobhatton »
Now this is where it starts getting harder to explain.
It is widely thought that water injection works by cooling down the air flow in the inlet manifold, so by putting the injector back by the TB or just after the inter-cooler the water will have more time to do its work. The problem with this idea is that there is not a high enough temperature in the air for the water to start absorbing it, there is also not enough time for that to happen and even if it did the water would expand with the heat and displace air flow, not what is needed.
By injecting the water in each manifold runner down by the head it has no time to displace air, goes into each cylinder in even amount, absorbs large amounts of heat changing to steam in the cylinders stopping detonation and knock, then the expanding steam increases the cylinder pressure and gives back what was lost by the cooling in the first step.
Lots more info here
http://www.mr2oc.com/showthread.php?t=350559
My son has just found the electronic controls I had made for my water injection systems, I will have to start selling them again.
Bob
phipck
Post by phipck »
dispite working at a college seeing people 10 years younger than me.....this thread makes me feel very young, i wasnt born till 2nd march 1984!
thats a realy interesting insight into your world.
Quigonjay
Post by Quigonjay »
bobhatton wrote:more details here
been reading up on the thread
will you be releasing a kit then? any details on them?
chrisf
hi
Post by chrisf »
hi bob.....impressive read mate
man i was born in 1982 lol.....looks like i sent the tubby head to the right man :thumleft:
