Also, any recomendations what to fit.
Cheers in advance
llcoolj wrote:I'm just doing mine too!
Fitted the front speakers(component 16cm pioneers) and a Kenwood 4channel AMP, now i'm pondering shall i stick in rear speaekrs or a sub
If its rear speakers then its 6x9's in the cubby boxes![]()
Rear speakers in the original position don't generate enough mid bass
llcoolj wrote:Hi All,
Managed to get the SUB in after making the fatal mistake of installing the AMP on the wrong side![]()
So after another 3hrs of stripping the interior and rewiring, the sub went in.
I got this Alpine 10" and box of ebay for 25quid, so it was quite a cheap option as a good pair of 6x9's would of cost me at least 40quid and they would of never would of kicked out as much Bass as a 10".
Good thing was that the sub box actually fitted quite well(dimension of box Bottom Depth 11 1/4", Top Depth 7.5", Width 15", Height 14").
I removed the passenger storage box lid and the box sat in at an angle, so the back was perfectly flush with the back of the 2, it also tilted the front of the box up so the seat could be reclined at a comfortable angle.
I put some velcro on the back of the sub so this stopped the SUB from moving forwards when braking, because the sub box sat in the storage compartment box it was not able to move side to side.
Would post some pisc but i feel a bit of a doughtnut as i am not sure how to![]()
llcoolj wrote:Hi all,
Some pics of me stripping the guts to install the wiring and some pics of the set up![]()
http://i33.tinypic.com/6syuci.jpg
http://i35.tinypic.com/33jqmgy.jpg
http://i35.tinypic.com/2aikfu8.jpg
http://i35.tinypic.com/2ebeayt.jpg
http://i33.tinypic.com/2wf0k7k.jpg
http://i33.tinypic.com/2hoir2a.jpg
I'm using the factory stock headunit as i didn't want to change it, as it might attract attention, it does the job too![]()
Total cost was£70
(Kenwood Amp
£45 came with free wiring kit, Sub/Box
£25, Front components were free off my bro
Thanks SW20GTS for the tip on how to upload pics
llcoolj wrote:There's not too much info of the box except the dimensions whichare
Top Depth 7.5"
Width 15"
Height 14"
And its not ported
Hope that helps
