[Mk2] [NA] front struts
deek
Post by deek »
can anybody put any light on this for me please #-o
own car 1990 n/a g limited import front struts leaking :cry:
local breakers has two struts from a 1989 g reg 2.0gti16 will these fit my car ? they look like they are rebuildables mines arent? 8-[
i will have to put my lowering springs on them will they fit ? :!: ](*,)
the struts in the breakers are dry and of reasonable condition but how can i check that they are ok ? #-o
cheers again guys :D
jmachling
Re: [Mk2] [NA] front struts
Post by jmachling »
AFAIK they should fit - it's actually a fairly common upgrade to put Rev 1 struts on later cars because they're rebuildable i.e. you can put Koni or other inserts in to uprate the suspension.
If you search on here about Rev 1 rebuildable struts you'll get some more info than I can provide :thumleft:
deek
Post by deek »
cheers for the info m8 :D
ive went ahead and bought them they seem to be fine and dry and in good condition 60 quid the pair :clap:
cheers again :thumleft:
