ill take a pic of the engine and post it,.
.just been to the local parts shop, had a word with the guy there, telling him about the leads,
The problem i have is, when i start it in the morning it strugles to start, i have to pump the excelerator a few times to get it started, once its started, its fine all day, turns over 1st time, was told if it was the leads, i would not just have problems in the mornings, would be more frequent or when im driving etc.
so that can't be the leads?
The vehcile has a cylinder head rebuild a few weeks ago:- listed parts.
Timing belt
head gasket set
oil filter
2x inlet valves
2x exhaust valves
set cylinder head bolts
engine oil
antifreeze
turbo blled vlave
pressure test cylinder ehad
re-face 12 x valves
re-cut 16 x valve seats
strip, clean, cyslinder head, refit cams, reset tappets
the chap who i bought it off told me at the time, it needs new leads, as the 1's used where from the celica as the mr2 leads he coudn't get in time?
im guessing now thats made up?.
.would it still run if it had the celica leads?
work was carried out by a company called PR0-TEC?
if it aint the leads, what else could it be
