spraying stainless steel/aluminium
Post by Martin F »
if spraying aluminium or stainless steel do you have to use etch primer as well as primer before painting? , anything else needed, it may have to put up with some heat too...
p.s. Is there anywhere online you can buy heat resistant paint in various colours ?
cheers :thumleft:
h3_5xy_j
Re: spraying stainless steel/aluminium
Post by h3_5xy_j »
Actually I've just found some heat resistant kawasaki green for my callipers on ebay....
I'll try and find the link, but its worth a look yourself 8-[
TubbyTwo
Post by TubbyTwo »
For stainless i always used to sand the area back then give it a good few coats of High temp paint.
Be worth checking with the High temp paints as some of them do not work with a primer as i found out #-o ](*,)
2003 Leon Cupra R, stage 2 Jabbasport remap to 280bhp
MR2 now sold :(
