Speedo going crazy!!
2barGee
Post by 2barGee »
My speedo flys all over the place when I drive the car, so there must be a loose conection somewhere! Can somebody point me in the right direction??cheers dan
platmatt8
Re: Speedo going crazy!!
Post by platmatt8 »
Top of your gear box matey, speedo sender unit. If your stood at the back of your car, reach down to the left of your intake manifold onto top of gear box i think it`s a 2 or 3 wire plug. :thumleft:
2barGee
Post by 2barGee »
platmatt8 wrote:Top of your gear box matey, speedo sender unit. If your stood at the back of your car, reach down to the left of your intake manifold onto top of gear box i think it`s a 2 or 3 wire plug. :thumleft:
ah cool, I will have a look tomorrow!! Could it be a loose wire behind the dash??
Moo
Post by Moo »
I've heard that speed converter chips can cause the speedo to do the same thing, both the ones that fit on the gearbox and the ones that go behind the clocks. It's one thing to consider if your running a chip type converter/delimeter.
platmatt8
Post by platmatt8 »
If you`ve had your clock out then it could be a loose cluster wire, but my money is on the gear box.
summ0004
Post by summ0004 »
I also had a similar problem that was caused by some speedo converter box
bazippy
Post by bazippy »
im having the same problem at the moment, the sensor on the gearbox appears to be fine(no rust,muck etcetc). took the clocks off and there seems no loose connections so i have bought a new speedo converter/delimiter in the hope its that. fitting tomorrow so ill see if it sorts it! hope you sort yours but itll one of those 3 problems!
bazippy
Post by bazippy »
Sorted mine out, i replaced the speedo converter but it may have been one of the clip connections that looked a little dody. either way thats how i mended mine, good luck with yours!
toxo
Post by toxo »
FYI the speedo signal is a purple wire carried through the firewall behind the passenger seat down to the passenger side kick panel where it goes through a big chunky connector then up round the dashboard to the instrument cluster where it is (from memory) pin 8 on the blue connector, which should be the middle one. If you think your problem might be cable related then you can check continuity between the passenger footwell connector and the instrument cluster, and from the footwell back into the engine bay.
