hi people. i have bought a second hand turbo. it has a bit of shaft play side to side. would it be ok to fit or would it need new seals?? thanks for your replies.
RobCrezz wrote:does it rub on the housing? side to side play is normally bad news, in and out play is less of a problem IIRC.
in and out is bad, every second hand ct20b, ct26 and hybrid turbo that i have felt have had varying amounts of side to side play, and thats quit a lot of turbos, guess its quite normal to have a little because it tightens up with oil pressure
must be a small amount though, if your not sure then get someones opinion who is
