Is it ok to fit tein springs to the standard black billies? or would they need to go on with uprated shocks?
Also...which decently priced, fairly low (35mm) springs are out there? except the tein
you can put lowering springs on standard black billies, but they are not designed for lowered/firmer springs, and due to this one of my rear shocks didnt last long atall after fitting my tein springs.
had tein springs fitted to mine,and they felt way to bumpy for the road and everyday driving.my mate has got apexi springs but on kyb shocks and they seem to work well.
The tein springs I've used are indeed green. I'm sure they do a range of different rates though, and I'm not sure what colours they use.
TBH I think even the yellow billies are underdamped for the springs I've got- the s-tech dress masters (in my opinion that is)
Looks like the same set up as mine. From Rogue? Didn't realise there were different rates. Be interested to know then what the range is and what I have.
R.
I don't suppose anybody knows the standard springs rates? I guess they'd differ between revs also? Thx for the Tein info ashman. No range then unless Rogue (or another) can advise?
Springs are pretty easy to get made up in whatever rates you want them, not too expensive either...
Don't know what the standard rates are, sorry.
I'm sure the Tien website listed several ranges of springs, but they tended to be grouped by the amount they lower the car not the rates they give- I'll have a look when I get home tonight (can't really search for that stuff whilst at work!)
ashman wrote:Springs are pretty easy to get made up in whatever rates you want them, not too expensive either...
No prob. The guy who owned it before me put these ones on, so im not sure. But they are hard and bumpy. too hard for my roads.
JTsai1 wrote:I've some trouble finding some of these myself (MKII spring rates) so hopefully this will help some people.
I'm not positive about some of these numbers and info, so if they're inaccurate, just post the right ones or let me know. Good luck shoppers!
I don't know if these stock figures are right, they don't make sense. Shouldn't be that similar.
1991 Turbo
F: 130lb/in. linear
R: 209lb/in. linear
1993 (don't know whether NA or Turbo, is there a difference?)
F: 130lb/in. linear
R: 210lb/in. linear
Suspension Techinique
F: 98-150lb/in (progressive) 1" drop
R: 179-235lb/in (progressive) 1" drop
TRD
F: 168lb/in (supposedly progressive, haven't seen the range though)
R: 308lb/in (same as fronts) both are 1.0" drop
Eibach Pro-Kit
F: 100-210lb/in. progressive, 1.0"
R: 140-303lb/in. progressive, 1.0"
Eibach Sportline
F: 74-189lb/in. progressive
R: 120-348lb/in. progressive
Tokico
F: 126lb/in.(supposedly progressive) 0.75"
R: 141lb/in.(supposedly linear, sounds way too soft) 0.75"
H&R Sport
F: 230-260lb/in. progressive 1.4"
R: 235lb/in. linear 1.3"
Tein S. Tech
F: 154lb/in. 1.5"
R: 274lb/in. 1.7"
HKS SF5
F: 46mm, 1.81"
R: 25mm, 0.98"
RS*R Down SUS
F: 176lb/in. 0.8"
R: 279lb/in. 1.0"
RS*R Heavy Duty Race
F: 201lb/in. 0.8"
R: 346lb/in. 1.0"
kg/mm S21 Race
F: 165lb/in. 46mm, 1.8" i think
R: 240lb/in. 25mm, 0.98" i think
Tanabe SUSTEC GF210
F: 2.3kg/mm=129lb/in. 1"
R: 4.1kg/mm=230lb/in. 1"
Espelir Active GT
F: 2.8kg/mm=157lb/in., 40-45mm, 1.57"-1.77"
R: 5.2kg/mm=291lb/in., 30-35mm, 1.18"-1.38"
Well, that's all for now, there you go.
stolen from us mr2oc
All I know is that the trd springs work very well with konis. Would be interested to see how they work with Billstien b6's though. teins dont look like they are progressive either.
