hi, i need to know the range of the rev2 turbo map sensor, i.e. voltage o/p against pressure, also it'd be handy to know the same for the NA map sensor.
are there any graphs for these specs?
cheers.
matt
I found this using google a while ago when I was looking for the same info for a Rev3 MAP sensor and it turns out he tested the Rev2 as well! http://gtfour.supras.org.nz/mapsensor.htm
HTH,
Nik
Tiny turbo + standard exhaust + aircon = 346bhp/300ft/lbs @ the hubs!
