[Mk2] [Turbo] what oil pressure does your car run
eminem0473
Post by eminem0473 »
hi i have just fitted a oil pressure gauge can anyone tell me what psi i should have on idle and also what psi under load?
Dale_V
Re: [Mk2] [Turbo] what oil pressure does your car run
Post by Dale_V »
mine runs at about 35psi idle, 45psi cruising, 70-75 psi under load
eminem0473
oil pressure
hi thanks for your reply mine only runs 20psi on idle and about 60 psi at 4000 rpm.
Dale_V
Re: oil pressure
Post by Dale_V »
eminem0473 wrote:hi thanks for your reply mine only runs 20psi on idle and about 60 psi at 4000 rpm.
in the toyota BGB manual it states a minimum of 4.3psi at idle, and at 3000rpm load 36 - 71psi, so you are well within spec :thumleft:
mine will probably be showing higher pressue due to me having a high idle (due to my cams not wanting to idle lower than 1000rpm), and due to it being a new tight engine build :thumleft:
Re: oil pressure
Post by Martin F »
nice info dale, been wondering for a while what the tubbies figures were :thumleft:
JJ
Re: oil pressure
Post by JJ »
Sounds good to me ! :thumleft:
Post by Martin F »
cantfindausername
Post by cantfindausername »
Mine runs around 60 pretty much constant from memory. Will pay more attention to the gauge next time I'm out. Lowers to 40ish when the temp rises to stock level. Normally lower though due to stock stat. Will have more accurate oil temps soon as I've got a filter relocation kit going on soon :D
***RIP Car13 ***
*** Now in an Evo ***
eminem0473
oil pressure
Thanks for the reply m8 its good too no my pressure is within the limits.Just a few more electrical glitches to sort out then hopefuly i can get it through its mot and actualy get to drive it.
