Unfinished 2.2l Turbo TRD Replica Project Car
Rogue
Post by Rogue »
Good points…
Registration Plate K22 TRD
The base car is an 80,000 mile 1992 Toyota MR2 Turbo.
The car has a TRD 2000GT replica body kit fitted.
The car has 18” wheels and tyres fitted.
The car has a Rogue Motorsport built HKS 2.2ltr engine
The car runs and is in a driveable condition, it was checked over with a view to getting an MOT about 6 months ago, since then its been sat.
The engine is built to a high spec, once the engine has been run in and mapped it should be good for 350-400 bhp! And much more with a bigger turbo…
The car is already fitted with a programmable ECU so it can be tweaked as and when you want to make any changes.
There are loads of extra goodies on this car, see the list below.
Bad points
Car has no TAX or MOT.
The bodywork needs some attention; the TRD kit is fitted and primed but needs some work before it’s painted.
It’s been sat for a while so there is a build up of rust on the brake disks etc, nothing major.
The car has lots of stereo wires + neons that need tiding up / removing.
I’m not 100% all the aftermarket gauges work, we can check prior to sale.
It’s a bit tatty in certain areas, it needs a good clean and tidy, if you’re looking for value for money and don’t mind a bit of a project then this is the car for you.
This car is strictly sold as seen so I suggest you view before you buy.
Spec List:
1992 Toyota MR2 Turbo, 80.000 miles
Revision 2 Toyota MR2 Turbo, 1992
Replica TRD Widebody kit, missing fuel filler cap - need prep + paint
Carbon fibre air outlet for boot lid (intercooler)
Manaray sport VR5 alloy wheels, 18x8 front, 18x9 rear - NEW
Falken FK451 tyres, 225x35x18 front, 245x35x18 rear - NEW
Lexus style rear light clusters
2.2 ltr Engine, built by Rogue Motorsport
Revision 2 3SGTE sleeved block
HKS 2.2 crankshaft
HKS forged con-rods
Custom 87.25mm Omega Forged Pistons inc Rings
Main bores line honed
ACL tri metal main bearings
ACL tri metal big end bearings
ACL Thrust Bearings
ARP Main studs set
ARP head studs
New toyota oil pump
New toyota oil cooler
Full toyota engine gasket set
1mm steel headgasket
Cylinder head
HKS 272 highlift camshafts
HKS vernier pullies
Re-surface cylinder head
Port polish and gasket match
Re-seated valves inc new seals
Sard 800cc injectors
Walbro 255/hr fuel pump in tank
FSE adjustable fuel pressure regulator
Turbo / Exhaust system
Turotechnics stage 2 hybrid turbo, 380-420bhp
Tubular 4 in to 1 exhaust manifold
3" turbo downpipe
Custom made quad exit exhaust system
Custom boot mounted large intercooler system inc shroud + fan
Blitz SS dump valve + air filter
Samco silicone hoses throughout
Link G2 X-LEM ECU with upgrade map option
Link 2 channel igniter
Twin coil pack ignition inc 8.5mm magnecor leads
Blitz SBC ID boost controller
Various gauges
Standard suspension with lowering springs
Front + rear aftermarket strut braces
Aftermarket drilled, groved + detailed brake disks
Red stuff front & green stuff rear brake pads
2x new rear handbrake cables
Sparco steering wheel
Sparco foot pedals
Alpine stereo headunit inc 8.5" TFT moniter
Clifford CAT 1 Alarm and immobiliser
This car was accepted from a customer in lieu of payment, and therefore owes me a certain amount of money. If you're interested in buying the car complete then please contact me vie phone or PM and we'll discuss figures. Otherwise, we'll break the car for spares in a few week's time. Please note that the vehicle will be sold as seen with no warranty whatsoever. I have no interest in picking up the liability for someone else's car. Please take the time to satisfy yourself of it's condition before making a decision. Settlement was reached amicably with our customer and we have all keys and documents for the vehicle and are the legal owners.
Offers in the region of £5,000.
agentturbo
Re: Unfinished 2.2l Turbo TRD Replica Project Car
Post by agentturbo »
Hi you may think this a silly question.. but was all the engine work done at rogue motor sport and if so why are you saying your take no responsibility for your work ? maybe its just me :oops: but this is how i am reading your ad..
nice project if you got an extra 3k to finish the job.
Rev 3 Kris
Post by Rev 3 Kris »
interested in the engine patrick i have a nice rev 3 engine in my 2 (only 48000 miles) but crave for more power any chance i could use engine as part ex on the 2.2
