[Mk2] [Turbo] Nurspec r flexi section gaskets? need one....
Dean_82
Post by Dean_82 »
Just fitted the downpipe today and when taking the nur's flexi off the gasket on one end just fell apart. So it needs a new one. Any idea where I can get one?
Everything is back together but it is 'blowing' ever so slightly where there is no gasket
If not, is it possible to just make one out of card?
(^I remember reading this somewhere^)
tarmac terrorist
Re: [Mk2] [Turbo] Nurspec r flexi section gaskets? need one....
Post by tarmac terrorist »
fensport normally do them
Baker
Post by Baker »
exhaust paste. As good as any gasket and cheap as coconuts.
Steve-O 2007
Post by Steve-O 2007 »
or you can get a sheet of gasket material and cut your own out.
I usually use exhaust paste even when using gaskets just to make 100% sure its got a good seal :thumleft:
