I've got my rev2 turbo for about 1/2 year
I've have the idle problem for a long time, it used to be idle at 800rpm at cold/just start, then idle at 1500rpm when warm/fully warm up.
I've check for vacuum leak and can't find anything.
also the oil light is always on for the first 2 to 8 seconds when I start the car
Last week, the car was send to rouge to check it, and changed cambelt, oil, oil filter, Spark Plugs, and fixed oil leak.
They've also check the fault code and found that the car have fault code of 52, which is the knock sensor, and they said it is caused by oil pressure issue of the engine as I told them about the oil light and knocking when start the car.
After all that, the idle stay at 1100 rpm.
The day after, the engine light was on again but car was jump to safe mode.
ECU reset after fitted the water temp sensor.
After the adjustment made by Rouge, the car is idle at 500 to 600 when cold start and sometime just stall after start, and I have to give it a throttle when start, and it idle at 1100rpm when hot.
No knocking when start, but oil light sometime stay on for 1 to 2 seconds.
Do you think the ECU of the car need replacing or I need another Idle valve or Knock sensor? it it really the knock sensor itself or other problem?
How can I kill the Idle problem?
The Knocking noice when start was not happening since last cambelt and oil change.
However, it happened again today.
and the idle is go up to 1400rpm
is it only the knock sensor cause problem??
Sorry about the long post and poor English but I hope people can understand it.
