Momo steering boss removal! HELP
pjm_morris
Post by pjm_morris »
Hi all,
The momo wheel in my 2 was never fitted straight (i suspect they lined up the wrong attachment as it has different spaced fitments on the boss).
So i'm trying to remove it it so that i can fit it straight.
I've removed the wheel and horn, and have loosened the centre nut. Should this now pull away? I've re-attached the wheel and in trying, feel like i'm about to pull the dashboard off! :shock:
Is there something I am missing here!?!?!?
fearless
Re: Momo steering boss removal! HELP
Post by fearless »
on some cars you have to have ignition turned 2 notches its to do with steering locks not sure on 2's worth a try though , dont forget to leave centre nut on you dont want a broken nose also try tapping with rubber mallet if not its going to be a puller job im afraid. :thumleft: :thumleft: :thumleft:
pjm_morris
Cheers mate, will give that a try.
Anyone else have any other experience doing this?
