Caliper bolts
Caliper bolts
Does anyone know where I can get caliper bolts for a mk1b? I rounded one off getting it out just now.
Re: Caliper bolts
i just went to MrT to get some for mine
(almost all
mine were stuffed, and i hadn't even touched them yet
I cant recall exactly how much they were but they weren't expensive, but just make sure you know what size bolt it is as I had forgotten and there were a few variants heh
G
G
Re: Caliper bolts
Mr T.
You don't say which bolt you've rounded.
(front/back or bracket or slider bolt), or whether you have a Mk1A or B
(i believe they are different)
There's a couple of threads with all the part no's if you do a search, the front ones I've just bought for a Mk1 B are
Slider bolts:
90119-09004 x 1 per side
90119-09003 x 1 per side
(ones longer than the other)
Bracket bolts are listed as 47710A, though not sure what that translates to in toyota parts man
"computer says no" speak.
Slider bolts:
Re: Caliper bolts
Yup, Toyota would probably be easiest and they're not that expensive.
See also here;
http://www.imoc.co.uk/forums/viewtopic.php?t=108521
See also here;
Re: Caliper bolts
Thanks for that, it is the slider bolts: the lower one.
Last time I tried to get them I wa told you couldn't get them any more though.
will try again later.
Re: Caliper bolts
Thats bo-lacks mate, I picked mine up last saturday! Took 2 days to come in mind, but they have them.
