foglights
foglights
do the lenses of the front foglights come of?as mine are dirty inside and want to clean them.
Re: foglights
Unfortunately they're a sealed unit.
You could remove the units, remove the bulb via the hole at the back, and stick something through that hole to clean them.
The problem will be getting the foglight units off the car though
Re: foglights
thought that would be the case.are they difficult to take off?had a quick look today theres just two screws holding them on i fink?
Re: foglights
There's an optimistic guide here.
http://www.mr-2.org/images/front_fogs/f ... /index.htm
Most people end up having to drill the screws out.
Re: foglights
sprayed some wd40 on them earlier so hopefully they should come out,if not just have to drill them.it says on the pics lense clip?does this mean there just clipped on?
Re: foglights
Once you have them off, stick them in the oven
(not my picture i spotted it somewhere?)
Re: foglights
BLZ-8027 wrote:Once you have them off, stick them in the oven
and gently roast at 220 degree's C.
For added flavour i use OXO stock cubes
Seriously, how long in the oven and what temp?
