[Mk2] [Turbo] Slightly odd coolant conundrum
01smiffy
Post by 01smiffy »
May have a very simple explanation this one, but I thought I would put it to the experts!
My 93 turbo began losing coolant a week or so ago, I had the car up on ramps today in the hope of diagnosing the location.
I found that I have a small puddle appearing underneath the front of the car, so i am guessing the rad has a small hole or something.
Where is the best place to get rads by the way?
Also, strangley, the overflow bottle was very eagerly pushing coolant out of the overflow hose when at first, then stopped when the level got low I am presuming, could this be because air is being introduced into the system from the leak in the rad?
going4the1
Re: [Mk2] [Turbo] Slightly odd coolant conundrum
Post by going4the1 »
Any leak from the radiator should really be visible if you had the front on ramps. Best to be certain before you invest. If it is from the very front of the car it will be either the rad or a perished hose connector. Any further back it could be the 'heater hose from hell'.
Any reputable Motor Factor will be able to supply a radiator. They are also available online and on ebay. Beware of units which are very cheap.
The expansion system will fail to work if the coolant in the expansion tank is below the level of the 'dip hose'. If it is below that then air gets sucked into the system. This usually results in air-locks in the heater curcuit meaning the heaters only blow cold.
blue2
Post by blue2 »
Got mine from here http://www.roguesystems.co.uk/forms/Product.aspx?ID=320 had it over a year now with no probs. :thumleft: All mr2 radiators are an absolute xxxx to fit, expect plenty of cut knuckles.
01smiffy
Post by 01smiffy »
Cheers for the replies guys! i am 95% sure it is the rad! im just gonna take the front bumper off and take a closer look to confirm.
Cheers for that link from roque, best price i have come across so far!
