[Mk2] [NA] Dont konw which Power Steering Fluid to use, please help.
wonga121
Post by wonga121 »
Hi everyone, I have got a Rev3 N/A with power steering, just dont know which one of the PAS fluid will work on my car.
Thx for the help
JohnnyC
Re: [Mk2] [NA] Dont konw which Power Steering Fluid to use, please help.
Post by JohnnyC »
None that's available in Halfords that's for certain :cry:
Toyota should be able to sell you some EH power steering fluid, it costs a packet apparently, and I'm not even sure how much you'd need.
I have heard that the Peugeot 307 uses electric power steering too, and that Peugeot sell their EH fluid MUCH cheaper. Whether it's 100% compatible though
:-k
wonga121
Post by wonga121 »
actually i think that there is something wrong with my Power Steering, I now need to turn the steering wheel really hard in order to turn the wheel itself.....
Is that any way i can fix that myself??
so, are you using PAS fluid from Peugeot now?
JohnnyC
Post by JohnnyC »
wonga121 wrote:actually i think that there is something wrong with my Power Steering, I now need to turn the steering wheel really hard in order to turn the wheel itself.....
Is the PS light showing on the dash? If so, it's fairly common, and often cured by turning the key from off to ign (not starting the car) about 20 times. Something to do with the relay.
Or might be worth checking for Power Steering ECU errors - search for that one as it's been covered before.
wonga121 wrote:so, are you using PAS fluid from Peugeot now?
No, I'm still running the original fluid in my 10 year old car, will probably change it in a few months though.
claw2k
Post by claw2k »
Hi Wonga
Didn`t you notice it wasn`t working when you drove away after purchasing it from RA Motors?
If I was you I would call him and get him to sort this out as well as your speedo too as it sounds like you brought a lemon if after 1 day of ownership parts of the car are damaged and not working.
HTH.
Ade
Image Image
1990 G REG MK 2 REV 1 ~ ORIGINAL TOYOTA PRESS LAUNCH CAR ~ CHASSIS: 304
Rev5GT
Post by Rev5GT »
claw2k wrote:Hi Wonga
HTH.
Dont be too quick to jump to conclusions....!! =; As far as i am aware there is NOTHING at all wrong with the PAS..
When the buyer came to buy the car he throught it felt heavier than it should - i thought it was fine and a little heavier due to having 17" alloys fitted.
Anyway after a bit of investigation we checked the PAS fluid and it was showing below the minimum mark.. I advised the buyer to get some for it on Monday as it was a Sunday and the parts/service dept at Toyota was obviously shut and i didnt have any lying around..! And i didnt want him going to Halfords and buying some in case it was the wrong one and causes further probs..
The price was also adjusted for this......
The car is by no means a LEMON - You only need to see and drive it to know that ](*,) :thumleft:
Razor04
Post by Razor04 »
get it from PEUGEOT its called EHPS fluid its identical to toyotas but about a quarter of the price.
its for electro hydralic power steering which the mr2 has.
ive been running it for 6 months without a problem.
Mr2'less
JohnnyC
Post by JohnnyC »
Razor04 wrote:get it from PEUGEOT its called EHPS fluid its identical to toyotas but about a quarter of the price.
Also, just a note for anyone not familiar with the mk2's power steering - it is actually quite heavy compared to other cars with PAS.
JOHNM400
Post by JOHNM400 »
I thought ordinary Auto transmission fluid was ok to use? Ive had it in mine since i changed the rack over a year ago with no probs :?
