Anyone know where I can get one at a good price
I've found one for
Dale_V wrote:how long do widebands last in general?
JJ wrote:Dale_V wrote:how long do widebands last in general?
Is that a trick question??!!
Mines lasted a year
My brothers supras on its 3rd one
I'm only going by the AEM one though
!! Im sure the more heavy duty portable types will last longer.
but I like having that information readily available if the engine runs lean
That's the same sensor (LSU4.2) -which is also supposed to be a factory fit item with the controller on VAG cars now so I would have thought there shouldn't be an issue with reliability??!!??Also sensor here any good? I know it's Innovate rather than AEM but compatible?
http://www.innovatemotorsports.com/xcar ... 250&page=1
prosser wrote:very good just broke mine![]()
so i was looking at getting one
JJ wrote:Stupid server..
lost everything I wrote again.
Did have a nosy at the site, good link..
but I'm a sucker for the AEM because of its digital readout and sweep.
and with an output for datalogging.
ideal tool for tuning too
Be sure to check for auxilary output voltage on these units as not all have them available.
Nitrous- A must.
and a must for the use of a wideband.
I had a narrow band that indicated I was still running plenty rich, using the SAFC2 to remove some top end fueling.
was inaccurate from the results of running nitrous and causing the motor to spit the plug electrodes through the turbo and out the exhaust
Combination of running lean
/ too much ignition advance as the AFC frigged the load values at the top end
= det
Get a decent clutch dale and you'll have a right hoot!
