I have a single din unit Sony m600r.
It has rca input for autochangers.
This might be an option to you.
I used the headphone jack to connect using jack to rca lead from Dixons
(about
£12).
Because the input on the unit was for changers only, the Sony would only select aux when a changer is connected so I had to buy an Autoleads lead that fools the headunit into thinking the aux rca input is a changer.
That was
£40.
The Denison is something I looked at but is
£100 and the only advantage is that you can control the I-pod through the head unit
(quite a big advantage I know, but has big compatibility problems I have heard.
Not sure if the above is clear to read.
.sorry
but it does work well, and quality is very good from my mini ipod
