[Mk2] [Generic] Headlight problem!!
terribleone
Post by terribleone »
Just got into my car after work, turned on the headlights and they didn't work!
The blue light came on on the dash, like the one that comes on when you have your full beam on. My full beam also works, just normal beam doesn't!?
Does this blue light come on when a bulb goes, as like a warning??? I can't imagine that both bulbs will have gone at the same time...so does it stop them both working if one bulb dies!?!?
As you can tell, in 4 years of ownership I've never had a bulb go on an MR2 before!! :oops:
Fuses are fine BTW.
Any help would be appreciated... :thumleft:
| REV3 G-LIMITED ANNIVERSARY EDITION | APEXI IN | MONGOOSE OUT | EIBACH SPORTLINES | CUSCO BRACES | H&T BUSHES | SUBTLE KIT! |
si2040
Re: [Mk2] [Generic] Headlight problem!!
Post by si2040 »
wiring it seems like or a motor issue...id wind them up and have a look..
MR2 Night Fox
Return to “Electrical”
