Wing Mirror Glass
Wing Mirror Glass
Ive recently purchased some wing mirrors from Oukie in black, and wish to spray them white.
How do you remove the glass?
Re: Wing Mirror Glass
carefully
Just have to be brave and lever them out of the casing.![](./images/smilies/spacer.gif)
They're located by a ball and socket in the centre plus a couple of plastic threaded adjusters which will sound like they're stripping but they're not.![](./images/smilies/spacer.gif)
Don't bother removing the glass to spray them, just mask it off.
They are easy to break when removing
(I know from experience) so if you can avoid it do
40 new from toyota for the glass, so be carefull ![Smile :)](./images/smilies/icon_smile.gif)
coverco wrote:Don't bother removing the glass to spray them, just mask it off.They are easy to break when removing
They are also very easy to break when you put them back in!
![Brick wall ](*,)](./images/smilies/eusa_wall.gif)
Also, you might want to sand them down very well if they're they later mirrors
![Image](http://www.xboxlc.com/cards/sig/default/viperrr2090.jpg)
Hi,
I do have a spare wing mirror at home which has been broken so i will have a go at removing the glass on that one first.
but usually with me i do something well the first time then do it badly wrong the second time lol
kaiowas wrote:Just have to be brave and lever them out of the casing.
Yeah, I sprayed the ones on my previous car and they do sounds like you're stripping the threads off when you take them out, but do it slowly a bit at a time and you should be ok.
I got spare glass from ebay for 99p, so it's always worth doing a search.
Gary.
