Would be interested to hear your opinions, how many people rustproof and how many people especially go to the trouble of waxoyling?
greglebon wrote:These cars tend to rust from the inside, especially the critical bits..
The damage is done before you even have an inkling anything is wrong!
The front lower chassis/ footwells are a prime example, as are.
.tah dah.
.the rear arches.
Always be wary of Ebay listings for MK1's where they say"the rear arches are solid, except for a little minor bubbling on the drivers side", etc.
That means, basically, a LOT of work(=£££), to fix properly.
Personally, I'd say that Waxoyling INSIDE the box sections(chassis, sills, rear arches, doors) will be far more effective than the bits you can see.
Make sure, though, that the drain holes under the car are clear..
Undersealing is good, dont get me wrong, but if you think about it, you're also sealing moisture IN above it..
.so make sure all drain holes are clear!
Conclusion? Do both!
widster wrote:greglebon wrote:These cars tend to rust from the inside, especially the critical bits..
.tah dah.
.the rear arches.
Thanks for the answer and it makes a lot of sense.
I have some more stupid questions:-
I have never done any waxoyling and to honest i am scared!![]()
Does it mean drilling loads of holes in strategic places and if so then do these need to be plugged to stop the moisture from getting back in?
Is there any diagram to show exactly where to waxoyl?
Perhaps i need to bite the bullet an buy a waxoyl kit.
Would you recommend waxoyling or undersealing first or doesn't it matter?
Finally, if you look under the car there are rubber bungs placed every so often and i don't know whet they are for?These aren't drain holes are they?
Widster
Jim-SR wrote:widster wrote:greglebon wrote:These cars tend to rust from the inside, especially the critical bits..
.tah dah.
.the rear arches.
Widster
if you drill holes then i would say DONT plug them back up.moisture finds its way in whether you leave it a gap or not.
if you plug up holes then you just remove its escape route
if a car is properly treated for rust then moisture and water arent going to be able to penetrate the treatments, so it wont matter whether you stop parts from being contacted by water or not.in reality no treatment is perfect and there is always a weak point somewhere, especially on a car that has rusted before
(unless these things are done properly at the factory and maintained throughout the cars life then youre basically screwed) but trapping water and moisture in places is about the worse thing you can do.
if the water is free to flow away
(and that includes evaporating when it gets warmed, if you have a bung stopping airflow then it simply turns to condensation again later) then that is probably the best protection you can get
the rubber bungs underneath the car are mostly there blocking holes that run from inside the cabin, but there are a few that go to internal cavities.
greglebon wrote:I bought the kit from Halfrauds, consisting of the refillable prssure tin, pump attachment and extender spray tube..
Now as I did the treatments on both of my cars, with a 3 year gap inbetween, the seam of the 1st can rusted in the interim period, so I had to buy a 2nd one for the SC last year..
Anyway, I reckon that 1 can should do you fine..
