[Mk2] [NA] Why do I end up warping the discs again!
Vindezal
Post by Vindezal »
When I break lately the car seems to go stop go stop till I break-nothing seviere at all but just in early stages. Break pedal not vibrating yet but Christ! Why do these things pop up at these times!
Any ideas. I think the discs especially are 35k old ish.
Reason I mention is that this has happend before. grr They dont just go thin and crusty instead.
Re: [Mk2] [NA] Why do I end up warping the discs again!
Post by Martin F »
could be many things other than warped discs mate, seized piston or sliders, rust build up on the discs, worn pads etc, need to examine them to determine the fault :-k
greeny
Post by greeny »
When you changed the disks did you clean the hubs up with a wire brush and copper grease aswell?
TOTB 2010 Rwd top speed, 1/4 and shootout winner.
10.7@142 on R888 street tyres, 10.3@134mph on slicks,
9's on slicks to come, with a clean full throttle pass! Goal of 0-150mph in a 1/4 of a mile....
marcnoonan
Post by marcnoonan »
Maybe you're just like me and thrash the f*** out of the car when you drive it? :-k :-k :-k
I managed to warp 2 sets of drilled and grooved? Problem it seemed was me having too much fun!
Marc
Everyone looks at me when I drive down the road now....... wish I could read minds.
Vindezal
Post by Vindezal »
marcnoonan wrote:Maybe you're just like me and thrash the f*** out of the car when you drive it? :-k :-k :-k
Marc
I like to think that ha ha never got on with the rears as they always squeaked when i breaked (werent oem). Yep will have to investigate
steve b
Post by steve b »
If brakes are not binding on and cooking then the only other ways to warp them are by spending too long on the brakes or coming in off a track and putting your handbrake on. By this I mean when they should be standing on them short and sharp instead are pushing on them not very hard and for longer than they should be.
Stock MR2 SW20 rev 2+ brakes won't warp if used properly. If they did warp all the race cars would have knightmare as they all run stock discs with uprated pads and racing on track is massively harder on brakes than any other use.
'97 mk1 Mazda Eunos Turbo track car with 260bhp/ton - soon more as Chris Wilsons going to build me an engine over the winter :o) .
marcnoonan
Too true Steve,
"Stock MR2 SW20 rev 2+ brakes won't warp if used properly. "
I'm on Rev1, but through experience have found that patten parts aren't as good as Mr T's so might be down to the false economy of buying ebay/cheaper stuff.
Marc
raptor95GTS
Post by raptor95GTS »
discs don't warp - they get uneven pad disposits left on the surface of the disc hence the run out issues. See steve b post above for how that can happen
MrGazz2
Post by MrGazz2 »
I know I'll be laughed off the forum but in my old Fiesta, if left to stand to long the rust would stop the brakes from working properly - made them really noise ect. It just need me to get the car up to speed and brake pretty hard a couple of times to free them up again...
Could be something similar perhaps? Just another suggestion.
Vindezal
Post by Vindezal »
change of pads? and re lube the sliders again? They do go clonk when i first turn the car on (pressing the break pedal) for the first time.
Would be great if someone local showed me how to do all this stuff than take it to a garage.
going4the1
Post by going4the1 »
'Clonking' brakes is not really a problem. This is caused by a missing pad support clip. If the clip is missing the pads slam against the pad carrier. You will probably be able to make the same noise if you immediately reverse and hit the brakes.
See:
http://www.mr2turbo.info/pics/frontbrake.html
Even if they are all present and correct - you will still get a clonk even if the backing tab is missing (see the third picture - that black square this sometimes corrodes away)
