[Mk2] [Turbo] Head light
gurteen0
Post by gurteen0 »
Today my right hand pop up light forgot to Pop up and is still asleep
Any ideas before I start to look for a new motor possibliy ?????? :?: :?:
Thanx :thumleft:
Note to self: Your Poor!!!!!!!!!!!!!!!
SFLee
Re: [Mk2] [Turbo] Head light
Post by SFLee »
check ur front bumber not blocking coming up
gurteen0
Post by gurteen0 »
Nope not that one ](*,)
Thanx anyway :thumleft:
toxo
Post by toxo »
Do you still have the front undertrays on your car seeing as you've got a border front bumper? If not it leaves the headlight mechanisms quite exposed, it might've just filled up with salt.
gurteen0
Post by gurteen0 »
Hi Toxo
I kept the undertray so its pretty clean underneath
Thanx anyway mate :thumleft:
toxo wrote:Do you still have the front undertrays on your car seeing as you've got a border front bumper? If not it leaves the headlight mechanisms quite exposed, it might've just filled up with salt.
syrus_sw20
Post by syrus_sw20 »
hi mate i have a perfectly working motor, with all brackets and arm,
just tested it the other day still working
Steve-O 2007
Post by Steve-O 2007 »
mine stopped working after my accident and I thought the motor was gone but I turned the knob behind the light to bring it up and then it started working again (must have just jammed) try that first :thumleft:
gurteen0
Post by gurteen0 »
Thanx Steve I'll give that a go first !!!! :thumleft:
gurteen0
THANX !!!!!!!!!!!!!!!!
Post by gurteen0 »
Thanx all :clap:
Its sorted now :D
Turns out it was only da casin around the light was loose catching on da bumper stopping it
Thanx anyway :clap: :clap:
