Another fuel leak...
TC
Post by TC »
I have found another fuel leak after my engine swap.
This time one of the main fuel lines. They seem to be 'crimped' at the joins and this is where its leaking.
See the yellow dot in the pic - this is where the leak is.
Can I repair this or will it just be best to replace the entire line?
If replace, any one know if mr T would still have the part?
If I source a second hand one I take it mk1a and b would be the same?
Tony jinxy froude
Re: Another fuel leak...
Post by Tony jinxy froude »
Mr t will charge a fortune for that, best bet is to get a good secondhand one, they are common enough to get, i dont have any at the moment, i must admit ive not ever come across someone needing one before :-k , Jinxy
crazylegs
Post by crazylegs »
kev to the rescue, pants on the outside. yours for the cost of postage and a packet of crunch creams. like tony i have never known them to leak. pm with your details and anything else you need. free if you want to take it off yourself.
