Hi,
My Tubby is finaly back together, but I have a slight problem with the Apexi Power FC.
The ECU seems to be running the fuel mixture way to week, If I try to reduce the injector
% to accmodate the new Sard 800cc injectors she wont start.
I put a scope meter on the O2 sensor yesterday to try and determin how the mixture was running and thats when it became apparant that she was running way to lean.I glad I havent taken her for a spin! There dosent appear to be any air leaks around the inlet manifold as I getting 3/4Bar vacume.
Ive tryed making some adjustments using the Commander but dont seem to be able to richern the mixture.
Any help with this problem would be appreciated.
Engine spec below:
Engine:
JE Pistons
Eagle Rods
PCI Cam Belt And Tensioner Kit
Sard 800cc Injectors
RHDJapan
GFB Light Weight Crank Shaft Pulleys
GFB AUZ
Stainless Steel Fly Wheel
(Lightened
& Balanced)
EZ Clutch
Paddle Clutch Assembly
(Rated at 500Bhp max input)
EZ Clutch
OEM Oil Pump
OEM Water Pump
Walbro 275Lts
/ Min Fuel Pump
HKS
"Slide" Varner Cam Pulleys
RHDJapan
HKS 264 Inlet Cam
RHDJapan
HKS 264 Exhaust Cam
RHDJapan
ARP Crankshaft Bolts
ARP Flywheel Bolts
ARP Head Bolts
Comtech Multi Layer Head Gasket
GTChris
Sytec Motorsport Fuel Filter
DemonTweeks
Upgraded Fuel System
& Fuel Rail
Amba Hydraulics
Adjustable Fuel Pressure Regulator
+ Gauge
Air Impulse Induction System
GTChris
Large Intercooler
& Pipe Work
Stage 2 Fensport Hybrid Turbo
(2Bar)
Tubular Exhaust Manifold
XSPower
3" De-cat Pipe
XSPower
HKS Hiper Exhaust system
(Not sure which to fit yet)
Departure Exhaust System
Samco Engine Coolant Hose Kit
DemonTweeks/Merlin Motorsport
Engine Management:
Apexi Power FC
+ Commander
RHDJapan
Apexi Power FC Boost Controller
GTChris
Rev2 to Rev3 Engine Management Conversion
3Bar MAP Sensor
GTChris
Air intake temperature sensor
GTChris
Inlet manifold temperature sensor
GTChris
Rev3 Ignighter
GTChris
4 Wire Lamba Sensor
GTChris
