any ideas?
cheers
RedMR² wrote:When I go to check my guestbook in"the garage" It won't view it.
I can't read the truncated text.
any ideas?
cheers![]()
RedMR² wrote:yep, used that following link, but I can't view peoples comments..
RedMR² wrote:any luck dude?![]()
poyntesm wrote:RedMR² wrote:any luck dude?![]()
No none..
.thought it might have worked for me and not for you due to permissions.
I logged out and was able to see it perfectly and can not spot what in the code would stop it?
Can you log out and see if you get the same viewing it as guest.If you have a different browser try that as well.
I am still studying that piece of code but so far can not find what would be stopping it.
"Great choice of bodykit, the parts work well together.
Do you have any other pics available?"
poyntesm wrote:Stranger and stranger..
.I will work with Dale and see if I can track it down.
Comment was"Great choice of bodykit, the parts work well together.
poyntesm wrote:Craig,
It is a problem with IE displaying the page..
.not sure why though.
You can see it prefectly in Firefox.
At least I know it is the HTML I am producing rather than the data not getting pulled from the DB.
Esmond
Should be fixed now..
.have a look and let me know.
Esmond
poyntesm wrote:Just studied the HTML for a bit..
.knew it was that rather than the data so that made life easier.
.basically I had some incorrect HTML but firefox knew what I was trying to do so rendered it.
.IE was stupid and just gave up.
Esmond
