ive fitted one and the hoses ive bought are too thin and just kink when bending them
I was wondering if i can twist the inlet
diycinema wrote:The way thats setup you might get oil accumulating at a low point in the inlet pipe but the air flow should prevent it building up too much.The stock can on the rev 3 avoids that, oil either drips back into the pcv outlet or falls into the catch can.
You would definitely want to avoid the chance of it kinking, if the flows restricted you might end up forcing blow by down the valve stems which wouldn't be good for performance or the engine.
Perhaps you could run the pipe with positive gradient to the can so oil doesn't accumulate.
